Change Rear Struts myself or have a shop do it?
Old 05-11-17, 11:54 AM
CDog77
CDog77's Avatar
Default Easier than I thought
In response to oldskewel, the bolt came loose pretty simple once broke free. I did not notice it being serrated.
I got the struts out easy enough. It was not that hard of a job as I thought it might be.
This video was very helpful.
I decided to go with the KYBs and am awaiting their arrival today and should have them back on soon!
Also in response to alignment of the strut assembly, I will be paying close attention to that aspect and will check out oldskewels link.
The video I watched discussed marking the position of the top bolts.
Old 05-11-17, 01:09 PM
lextout
lextout's Avatar
isn't it insane how they gave you a quote thats almost 40% the value of the car.
Old 05-13-17, 08:34 PM
CDog77
CDog77's Avatar
Default Finished up the Job
Hey, thanks for the helpful tips. I got the struts on the rear of my 1996 LS400. The biggest challenge I had was to get the the alignment correct between the the top and bottom of the strut. I had to re-compress the spring 3x on the 1st and 2x on the 2nd strut to get the bottom through bolt to line up. It was nearly a 100 degrees in the desert and I was quite verbal with my Lexus parts at that point, but managed to get her done.
The ride is much improved! I am glad I put the KYB's on. I did opt to not replace the strut mounts. The ones I had seemed fine and saved me a 100 bucks (Thanks Oldskewel)
I think I will tackle the fronts next weekend!
tholmqu
07-19-15 04:36 PM
robbyk
01-12-15 07:16 AM
KMinAF
29
02-09-12 04:26 PM
eddied106
06-08-03 10:33 PM
92lex
03-09-03 10:40 PM
Quick Reply: Change Rear Struts myself or have a shop do it?
