es 330
es 330
Hi, I have shake in the steering wheel back and forth at low speed. 167k on the vehicle. I suspect many things in the front end need replacement. Hope to do it all at one time. Any help on what parts to get would be greatly appreciated.
wrong section but there are too many factors to consider here. it would be more beneficial for you to ask in the right section with folks more familiar with the car's tendencies and wear points.
easiest thing to check is the condition of the tires and balance of the wheels. you can rotate them front to back and see if the problem persists. how are they worn? any feathering or uneven wear. check the tire pressures and make sure they are even left to right.
ThumperPup
ES - 5th Gen (2007-2012)
43
04-03-19 07:30 AM
