Adus 505 Replacement Bush (Rear Carrier Arm Bushing Replacement)
Hello all,
Please can somebody help me the correct OEM parts to replace ADUS 505 Bushing. i need to change my Ls400 Rear Carrier Arm Bushing. kindly check the image i have attached.
thank you all
thank you all
Not sure what you're asking and also don't know which year you're asking about, but here's the bushings thread that helped me a while back when I was researching the bushing IDs for my own car. Of particular help is fencera's post detailing the specific P/Ns. Hope this helps!
anthonyini (03-11-18)
NEED HELP? - title your post appropriately...
PLEASE use a descriptive title in your "Please help", "Need Help" "Help" posts. As an Example "Need help- '98 car does not start". "Need Help - '98 spongy brake pedal".A generic "Need help" is going to return several thousand "need help" titles. Do you want to read several thousand to find an answer? For the benefit of those who may have similar troubles your precise title will help them find the answer quickly and return accurate search results.
In the body of text:
Year, miles on car and description of problems/symptoms.
The following 2 users liked this post by billydpowe:
anthonyini (03-11-18),
pandito (07-21-17)
LS_4Will
12-22-04 09:53 AM
