98 gas leak
Old 05-15-17, 09:42 PM
Black98LS
Black98LS's Avatar
Default 98 gas leak
I have a 98 UCF20 230k miles sometimes when I start the car it will smell like raw fuel and you can actually see it dripping under the car from between where the exhaust goes up to the engine. I can cut the car off and start it back and nothing will drop. It's very intermittent only does it sometimes. I have checked everything that I can possibly reach under the hood and nothing smells like gas. Any ideas?
Old 05-16-17, 07:31 AM
YODAONE
YODAONE's Avatar
See attached Lexus fuel system components diagram in engine compartment. If unable to sort it out hire a professional and avoid a fire.
Old 05-16-17, 10:09 AM
oldskewel
oldskewel's Avatar
Nice pic. The parts labeled 23270 might be good candidates for close inspection.
Also, this post (for my '91, I don't know how similar the newer cars are, but hopefully something close):
https://www.clublexus.com/forums/ls-...ml#post9777959
Shows how you can basically hot-wire your fuel pump (just a paperclip will do it for these purposes) to run continuously so you can have the system staying pressurized while you search for the leak - no need for the engine to be running or hot.
Fuel leaks are usually rare ... because cars don't last very long if they exist.
Ef8people
02-09-14 10:56 PM
jrwfly
Performance & Maintenance
05-21-09 08:54 PM
GFerg
05-09-06 03:50 PM
Canyonero
Maintenance
07-29-05 02:05 AM
Quick Reply: 98 gas leak
