Rear defroster how to inspect
I recently relocated to Michigan from AZ, and found myself using the rear defroster a lot more than I ever did in AZ.
The first time I go to use it here, it's not functioning at all. I believe the side rear view mirror are working since those aren't fogged up.
I checked the fuse for the rear window under the dash, which was good, and the switch also turns on and lights up the LED when I press the button.
Next I was going to check the contacts on the rear window, but has anyone made a diy on how to get access to them? Do you have to take the rear seat back out to do this?
The previous owner put limo tint on there so dark, I can barely see out, let alone inspect the lines of the grid.
jason60050
03-11-10 11:41 PM
