Gremlin Inside HVAC Unit?
Old 06-01-17, 08:36 AM
VolumeToo
VolumeToo's Avatar
Question Gremlin Inside HVAC Unit?
I have a 1998 model, which I bought a couple of months ago. One of the first things I noticed, when slowing to a stop, was the sound of "something" in the ducting (maybe) sliding uphill, then down again. It's not a clattering sound, more like a mild swishing. I don't think its the air flaps moving, as I don't normally have the climate system in auto mode.
Is there anything that's known to break off and roll around?
The car did have one of those hideous aftermarket Nokia phoneholders (not too well put in, I hasten to add), and I've removed most of the superfluous cabling/boxes etc. associated with that. But this weird sound remains. (I just hope he didn't drop a fastener - or whatever - into the main air vents).
Any thoughts?
Old 06-01-17, 11:51 AM
timmy0tool
timmy0tool's Avatar
sounds like there was something foreign sliding around in the vents as you suspected. try to set the vents to a particular setting and see if you can "trap" the object. I would just take the head unit out and inspect the vents.
Old 06-02-17, 01:16 PM
deanshark
deanshark's Avatar
There was just another thread about the same thing.
https://www.clublexus.com/forums/ls-...e-removal.html
He never found his "marble" but if you need to take out the console and stuff that thread might help you.
Old 06-02-17, 02:06 PM
VolumeToo
VolumeToo's Avatar
Thanks for reply. Certainly not a marble, sounds more like a small bag of sand. What I have noticed (and not yet investigated) is that one end of the front demister outlet trim piece is sticking up slightly - so whether a clip has fallen in I don't know. But the weird thing is, when slowing to a stop, there's more of a delay before the "return swish" than I would expect.
GS350MANN
05-18-19 04:40 AM
sdccards
05-04-15 02:40 PM
takaiguchi
RX - 1st Gen (1999-2003)
02-21-12 08:18 PM
vinegaroon
03-28-06 02:20 PM
TRD_Power
Maintenance
08-11-05 12:00 PM
Quick Reply: Gremlin Inside HVAC Unit?
