Just bought a 94 LS, basic tune up?
Old 06-08-17, 07:41 PM
westopill
westopill's Avatar
Default Just bought a 94 LS, basic tune up?
Just picked up a 1994 LS as some members may already know. I plan on giving it a tune up as well as an oil change as you should buying any craigslist car. One thing I plan on doing is cleaning out the MAF sensor, but what do you guys recommend as far as giving it a tune up? I know there's spark plugs and what not, but any advice on what I should do to increase MPG's or power on a 23 year old LS?
Old 06-08-17, 08:06 PM
evan55
evan55's Avatar
If your doing spark plugs and ignition wires, I would recommend doing the distributor caps and rotors, and do the coolant temp sensor.
Old 06-08-17, 08:12 PM
westopill
westopill's Avatar
I've heard of changing the coolant temp sensor on around the forums. I'll have to see where I can find a good OEM replacement, as I understand the Lexus OEM isn't too cheap.
Old 06-08-17, 08:15 PM
evan55
evan55's Avatar
I would recommend the OEM one from Toyota
https://www.clublexus.com/forums/ls-...ange-pics.html
Old 06-09-17, 02:30 AM
deanshark
deanshark's Avatar
DO NOT clean the AFM. You'll ruin it.
Old 06-09-17, 07:57 AM
dicer
dicer's Avatar
X2 RUIN IT new ones are about $700.
Never done it but I think the only possible way they could be cleaned would be to take it apart if possible, and that may ruin it as well. There is a mirror in them and photo receptor that would need cleaning, your just messing them up with any sort of cleaner, its a small hole and any contamination will not evaporate and leave a film on those parts.
Old 06-09-17, 08:17 AM
westopill
westopill's Avatar
Good to know, I didn't realize it had a AFM not a MAF. lol, glad i brought that up on here before ruining it. I'll stick to finding a OEM coolant temp sensor and some OEM spark plugs as well.
Old 06-09-17, 08:22 AM
dicer
dicer's Avatar
Glad you found this all before you did it.
Old 06-13-17, 09:59 PM
westopill
westopill's Avatar
Default Where to buy OEM quality parts for cheap?
I'm looking into doing this tune up sometime next month. I found what I think are some good OEM quality plugs, wires, pcv, and pcv grommet which I will link down below. I can't seem to find many good sources for OEM quality cap and rotor at a reasonable price. I found this cap and rotor kit on Amazon, but don't really trust that its any good:
Amazon Amazon
Any recommendations would be much appreciated!
Heres the parts I've gathered thus far:
PCV:
Amazon Amazon
PCV grommet:
Amazon Amazon
Wire set:
Amazon Amazon
Spark plugs: Long life Denso iridiums @ Rockauto.com
Old 06-14-17, 07:15 AM
evan55
evan55's Avatar
I ended up using YEC caps and rotors, which are made in Japan and seem to be good quality. They were about $90cad.
I ordered them them through the Toyota dealer, you can also get them online
Old 06-14-17, 06:45 PM
timmy0tool
timmy0tool's Avatar
in my opinion, there is no need to go Denso OEM for the spark plugs. you will be fine going with NGK iridiums, easily bought at your local auto parts store for much less than OEM.
Old 07-05-17, 05:20 PM
westopill
westopill's Avatar
Default Parts have arrived! Tune up will begin soon!
Hey all! Just got my shipment from rockauto today. Im pumped! I got Beck arnley cap and rotors, Denso Long life Iridium spark plugs, and NGK wire set. Can't wait to get started! Wont be getting into to it though until after next week as I'll be on vacation.
Old 07-05-17, 08:45 PM
evan55
evan55's Avatar
Looks good...hope you got two caps and two rotors..
Old 07-06-17, 05:20 AM
Rokas
Rokas's Avatar
I'm gonna be watching this thread. Can you please take pictures and detailed steps when you do the wires? It would help me to learn about working with the electronics in cars.
Also, how do you tighten your spark plugs? Do you tighten them until you feel it "sit" and give it one more half turn? Sorry, I'm struggling with words right now. What I mean is I know that you're not supposed to overtighten (or undertighten) spark plugs so I need a reminder on how to do it. I'm gonna do the spark plugs in mine soon.
Let us know what kind of performance enhancements you see.
Old 07-06-17, 06:01 AM
westopill
westopill's Avatar
I did, just took a picture of one of each.
Rokas,
I can make some steps here on this thread. Check out this link also: http://www.lexls.com/tutorials/ignition/sparkplugs.html This guy has a ton of tutorials on the 1st gen LS. As for tightening the spark plugs, I usually tighten till its hard to turn, then go a little over a quarter turn. On the tutorial it says to tighten to 13 ft lbs.
Quick Reply: Just bought a 94 LS, basic tune up?
