Gear Shift Indicator lights do not work upon engine start but ok later
Guys,
LS 400 1995 with 150k miles on it. Recently swapped out the transmission with a used one.
Car runs great and gears shift smoothly. One thing I have noticed is that the gear indicator lights on the dash do not turn on till about 5 min of driving. The Cruise control feature does not work because of this. After about 5 min of driving, the lights flash and turn on and cruise works normal.
Any suggestions guys?
It is a typical symptom of a NSS begins to fail. You should had used the original NSS to your new transmission or just to use a new one. There is a way to fix it cleaning the contacts mechanically or electrically though.
https://www.clublexus.com/forums/ls-...ml#post7751206
deeveeance
RX - 1st Gen (1999-2003)
05-16-18 04:40 AM
sivikvtec
Performance
47
05-12-10 05:08 PM
