1996 LS400 Instrument Panel Brightness
You know how during the day the instrument panel and temperature and time in the center console are very bright since its sunny, but when you turn your headlights on at night, they go into a dim mode as not to disturb you? Well even with my headlights off they are all stuck in dim mode! Its not the worst thing I can still see the instruments just fine, its more annoying looking at the temperature and time. I'm just curious what it could be if anyone here has any ideas it would be super appreciated! I did play with the brightness ****, it works fine but doesn't turn off the night mode.
when you start the car, are all the needles nice and bright, then dim out? this may be caused by a faulty light sensor at the corner of your dashboard, to run the auto headlights.
also the switch stalk, where you turn to switch on the headlights, might be bad as well. try jiggling and pushing the stalk in towards the steering column to see if it corrects (having the switch in OFF, and car idling). the contacts might be dirty or intermittent.
I'll try to play with the headlight stalk a bit and see if that helps, thanks for the suggestion.
It's not supposed to go to the same brightness as daytime just so it doesn't distract you at night. I keep mine at only one click up at night. I wish there was a way to even turn it down during daylight. Maybe I'll try covering the sensor on the dash so it thinks it's night. (That just came to mind )
I know its not supposed to be bright at night.. There is a way to make it dim at daylight with the **** even. What I am trying to convey is the night time mode is stuck like that in day time. I need it to be brighter in the day. Its stuck at the night time level.... ! you can lower the brightness to even zero or off or close to off with the ****.. the **** works great for me.. its just not going to day time brightness!
darkdream
08-31-09 05:01 AM
mikevanle
03-08-07 10:15 AM
kms910
09-18-06 12:51 PM
