Oem gasket set
Old 08-10-17, 06:53 AM
shlomy2000
shlomy2000's Avatar
Default Oem gasket set
hey all,
Unfortunately ive reached to a point that my engine's heads are twisted (2000, 126700mi), all of my cooling system components are new (radiator, thermostat, water pump, coolant etc) and the mechanic didnt find and leaks, when we spun the engine by hand you could see bubbles from the reserve coolant tank, porbably fromer owners heated up the engine.. so i need to buy a gasket set, now ive found couple after market once (domestic gasket, ITM gasket) on ebay\amazon. the question if they will do the work or should i order OEM/Genuine, and where can i find genuine gaskets?
Thanks
Old 08-10-17, 10:15 PM
dicer
dicer's Avatar
Some will say yes to OEM, and some will say it does not matter. The story is, where are the OEM ones made? OEM's always out source for some of their parts, so buying the off brand ones may be exactly the same outfit that makes them for the OEM. I'm sure Felpro makes 1UZFE gaskets.
http://www.partsgeek.com/catalog/200...ad_gasket.html
shlomy2000 (08-13-17)
tptpete
Build Threads
20
08-22-17 08:13 AM
sam12345
01-24-13 04:28 PM
89MA70
Performance & Maintenance
10-12-09 07:44 AM
mikeloc24
SC400 / 300 Classifieds
07-16-07 01:25 PM
Quick Reply: Oem gasket set
