Power steering lines
Old 06-29-20, 12:27 PM
  #31
RA40
Super Moderator
RA40's Avatar
The #2 return line on mine is leaking. Called around and was told that there were 8 left in the country. Now 7 since I ordered one. These factory parts for the PS system are going to be rare soon. If you intend to keep yours and want the genuine parts better get these hoses!
Old 06-29-20, 06:52 PM
  #32
96DWPLS400
96DWPLS400's Avatar
I just checked Partsouq and they show 0 available. Hate when this happens - I don't need it but don't want to be without when I do.
I've got other issues now. I buggered up the oil seal when rebuilding the pump (I think cause I didn't lube it before pounding the shaft in). Ordered a new one from LexusPartsNow and just got an e-mail saying it's unavailable and no ETA when one will be available.
Old 07-01-20, 11:08 AM
  #33
RA40
Super Moderator
RA40's Avatar
That's yet expected now that our cars at at this age. The local Lexus dealer is checking some of the other PS return line availability. I suspect we'll be left with using the 9.5mm hoses. Did find this 10mm ID hose:
https://www.belmetric.com/coolant-ho...mm-p-7073.html
Old 09-17-20, 01:26 AM
  #34
spuds
spuds's Avatar
So looking at that hose,those specs should be fine for it?
RH10COOLANT - Coolant Hose 10mm
Pricing:
$15.23
Add to Cart:
Cohline Metric Coolant Hose
Outside: Smooth Rubber
Inside: Smooth Rubber with Polyester Braiding
ID: 10mm OD: 17mm
Working Pressure: 4 Bar or 58 PSI
Bursting Pressure: 12 Bar or 174 PSI
Temperature Range: -40F to 248F
Made in Germany
Hoses are cut off a continuous spool, charged by the meter.
Roll length (longest continuous cut) is 20 meters.
COHLINE Part No. 2035 0800
  • Model: 2035 0800
  • Manufactured by: Cohline
Old 09-17-20, 06:34 AM
  #35
sdls
sdls's Avatar
Pricing:
$15.23
Add to Cart:
ID: 10mm OD: 17mm
Made in Germany
  • Model: 2035 0800
Wont coolant hoses soften up and weaken with exposure to the PS fluid?
bradland (09-17-20)
Old 09-17-20, 10:11 AM
  #36
spuds
spuds's Avatar
Maybe this?
https://www.napaonline.com/en/p/PSK76578
$16.29/Each
Contents (1) Hose
Manufacturer Plews Edelmann
Manufacturer Part Number 80564 08B
P/S Hose End Type 10MM I.D. Molded Return Hose
Power Steering Hose Imperial Length 16"
Power Steering Pressure Hose Thread Size N/R
UNSPSC 40141764
VMRS Code 015013011
Old 09-17-20, 10:23 AM
  #37
bradland
bradland's Avatar
Maybe this?
$16.29/Each
Contents (1) Hose
UNSPSC 40141764
VMRS Code 015013011
Just buy 1 or 2 foot of bulk .375" fuel/oil hose from any auto parts store. 10mm hose is not available in bulk in the USA so it will be tight. 3/8"(.375) = 9.52MM.
Should be less than $5 per foot.
The following 2 users liked this post by bradland:
RA40 (09-17-20), spuds (09-17-20)
Old 09-17-20, 10:29 AM
  #38
spuds
spuds's Avatar
This filter says it will fit our cars.Im seeing them online,various manufacturers saying 3/8ths-10mm.Think thats really going to make any difference?
https://plews-edelmann.opticatonline...=usa&ctx_iam=1
When this innovative, newly designed filter is installed in the return line, it filters out metal particles and rubber flakes, which can naturally occur in a power steering system. When installed with a new pump and hose, along with a proper flush, this filter will help eliminate pump warranties and keep the system working trouble free for many years to come!
Omega Hose 70700 Power Steering Filter
Manufacturer Website: https://www.plews-edelmann.com/
Brand: Omega Hose
Item/part Number: 70700
Part Type: Power Steering Filter
Item/part Status:
Old 09-17-20, 10:43 AM
  #39
spuds
spuds's Avatar
Though Im sure if you are OCD enough you could find a manufacturer to apply a Nasa ceramic/titanium coating,have it laser cut to 10mm,have it laminar flow tested,run it on a dyno and would only cost 1500 dollars.I should do a thread on that.....
bradland (09-17-20)
Old 09-17-20, 10:56 AM
  #40
bradland
bradland's Avatar
Brand: Omega Hose
Item/part Status:
The LS400 PS already has 2 filters. One at the bottom of the reservoir and another in the PPS solenoid which fits into the rack close to the pinion.
Adding a third filter isn't a bad idea but it could eventually clog and starve the system of fluid.
Old 09-17-20, 11:12 AM
  #41
spuds
spuds's Avatar
One at the bottom of the reservoir and another in the PPS solenoid.....
I was reading folks having failures on those screens....in which case here is a work-around.
Old 09-17-20, 11:54 AM
  #42
Superfast1
Superfast1's Avatar
I've been using the ArmorMark 50063 3/8" (9.5mm) fuel line rubber hose for the return line for over 6 years & it's perfectly fine. Pepboys carries it for only $1 something per linear foot. Just coat the inside w/ ps fluid then the metal tube will slide right in.
spuds (09-17-20)
Old 09-17-20, 12:32 PM
  #43
bradland
bradland's Avatar
Sadly, the majority of those "Failures" is nothing more than the screen becoming clogged which means it's doing it's job.
The problem is the owner not keeping the screen clean.
Old 09-17-20, 05:56 PM
  #44
spuds
spuds's Avatar
Where the high pressure hose connects to pump,the banjo bolt,does it have a washer? Boy was that sucker hard to get off.I cant find any clear lexus pics.
Old 09-17-20, 07:03 PM
  #45
bradland
bradland's Avatar
Yes
Any Toyota dealer should carry it. Part number in the photo is correct.
spuds (09-17-20)
Quick Reply: Power steering lines
