1998-2000 ls400 power steering reservoir bushings
Old 08-25-17 | 07:05 PM
YODAONE's Avatar
YODAONE
Default 1998-2000 ls400 power steering reservoir bushings
In 1998 the LS400 isolated the power steering reservoir from the vane pump assembly by mounting on the right side fender well.
Three rubber isolation bushings were used in affixing the pump to the fender well.
Anyone with a 1998+ LS400 will notice their bushings have shrunk and are age and heat hardened....allowing the resorvoir to flop around.
It is the authors opinion the original bushings were poor quality rubber and ill fitting to begin with
Time to replace...
Unfortunately, Lexus has discontinued these rubber bushings....
Found a solution at AutoZone (Ahem)
They carry a line of "Help" parts on pegboard hangers where I came across a package containing 3 bushings.
DEAR ADMINISTRATOR:
AM UNABLE TO.UPLOAD IMAGES TO FINISH THIS POSTING....USING SAME CAMERA PHONE WITH SAME INTERNET SERVICE.
PLEASE ADVISE..
THANKS..
Old 08-25-17 | 08:38 PM
YODAONE's Avatar
YODAONE
[QUOTE=YODAONE;9964925]In 1998 the LS400 isolated the power steering reservoir from the vane pump assembly by mounting on the right side fender well.
Time to replace...
3-pack of windshield wiper motor bushings from Autozone...# 49450..complete with better fitting metal spacers
Aftermarket rubber bushing/spacer at top , OEM rubber bushing/spacer at bottom.
OEM bolts inserted to show utter disregard for fitment of originals
Top view of reservoir depicting mounting points.
Another mounting point beneath coolant reservoir.
Push spacer out to remove original.bushings...
They will likely disintegrate in half, but removing spacer makes job easier
New bushings fit perfectly in bracket holes and match bracket thickness
Diagram at upper left depicts resorvoir, rubber bushings, spacers, and bolts.
Lexus discontinued these rubber bushings...although every 1998-2000 LS400 tequires replacement at this point.
FOR SAFETY...BEFORE unbolting the resorvoir and replacing these bushings, be aware that both rubber hose sections are likely brittle and will likely fracture .or be disrupted.. requirimg immediate replacement...
Plan ahead....
Replace both hoses and clamps.
The larger diameter bottom hose is sold as a service item from Lexus (DO NOT SUBSTITUTE) while the smaller diameter 6" hose segment is not sold separately from a very expensive hose assembly..
You can however source 10mm ID ATF rated hydraulic hose. Mind the wall thickness..
3/8" ID hose (9.5 mm) does not work well because it is difficult to push onto the steel.lines and if not careful.you can fracture line fittings..
This is correct hose... Yokohama is the OEM supplier.
ANYONE WITH SOURCING?
Old 08-28-17 | 02:10 PM
timmy0tool's Avatar
timmy0tool
I understand replacing these worn bushings but to what benefit? I think replacing this causes more issues, such as replacement of that hose.
Old 08-28-17 | 02:42 PM
YODAONE's Avatar
YODAONE
<br /><br />First, the OEM determined to secure the Power Steering Resorvoir to the chassis via rubber bushings.<br /><br />Due to OEM rubber compound selection , underhood location (high heat), poor original fitment and age, these bushings harden and shrink such that the P.S. tesoirvoiflops around....<br /><br />So, the brittle and rock hard hoses connected to the P.S. resorvoir stand greater chance of fracturing and blowing out suddenly.....very unsafe.<br /><br />So for safety's sake, the bushings and hoses should be replaced at same time.<br /><br />Practice proactive maintenance...
Old 08-30-17 | 03:13 PM
timmy0tool's Avatar
timmy0tool
ah gotcha! blow out is unlikely but a light leak is more probable due to the extra vibes on the overly brittle hoses. thanks for clarifying.
Old 08-30-17 | 05:22 PM
YODAONE's Avatar
YODAONE
On 20+ year old rubber hose, a blowout is more likely than not when failure occurs.
An LS400 may look good, but the rubber hoses (albeit excellent quality) do not last forever in a heat/hydraulic pressure environment.
The best military grade silicone rubber has a shelf life of 25 years...
SAFETY is paramount and proactive maintenance is necessary for rubber P.S. and brake hoses to avoid unwelcome surprises.
Not aftermarket stuff either.
Old 09-01-17 | 10:26 AM
timmy0tool's Avatar
timmy0tool
agreed. I was servicing a car and saw some cracking on the brake hoses which worried me! though i have not seen any catastrophic failures in my years of driveway wrenching, it's definitely a concern.
Old 09-03-17 | 08:21 AM
UNCNOR's Avatar
UNCNOR
Default "HELP"Bushings 49450
How many bushings are needed to secure the PS pump properly?
Old 09-03-17 | 09:34 AM
YODAONE's Avatar
YODAONE
The Power steering reservoir in 1998+ LS400 requires 3 bushings.
The bushing kit recommended includes exactly 3 bushings.
Check your hoses...
UNCNOR (09-03-17)
Old 04-19-18 | 07:50 PM
YODAONE's Avatar
YODAONE
Check your hoses...
Replaced P.S. Resorvoir hoses described above on friends 1998 LS400....
One had a hairline crack and was slowly leaking P.S. fluid...just waitimg to burst. ..
Anyone with 1998 + LS400 should probably replace P.S. boses...
spuds (04-20-18)
Old 04-20-18 | 06:40 AM
spuds's Avatar
spuds
Good maintenance advice,thank you.
Old 04-20-18 | 09:11 AM
EthanS's Avatar
EthanS
Thanks for another thorough write up YODAONE!
When I first got my '99 in 2013 I was chasing a power steering leak. Turned out to be one of the hoses connected to the bottom of the reservoir. The hose was actually permeating fluid throughout the entire length, likely due to tiny splits and fractures from the dried up rubber combined with the vibrations from the worn bushings.
The hose was so cooked that I had to take needle nose pliers to it and rip it off, bit by bit, chunk by chunk... The original reservoir bushings remained for 5 more years; I will be replacing this weekend!
Old 05-22-20 | 11:51 AM
YODAONE's Avatar
YODAONE
Default Update on dorman bushings
The Dorman rubber bushings are beginning to crack from the heat.
Located a more durable silicone variant from
ZSPEC Design
www.zspecdesign.com
Available in black, blue and red silicone.
Will advise results.
Stay tuned.
Old 05-22-20 | 12:28 PM
RA40's Avatar
RA40
Super Moderator
Would be nice if they listed a durometer hardness to these. They have some cool products, glad you found and posted them.
Old 05-26-20 | 06:01 PM
YODAONE's Avatar
YODAONE
Supplier to provide durometer...
Meanwhile, have installed the new silicone bushings....the Dorman parts that were used to replace OEM bushings displayed considerable cracking.
New silicone power steering reservoir bushings
Silicone bushing conforms into bracket mounting hole with similar effort as OEM bushings.
Cracked Dorman bushing on left... Silicone bushing on right. Reuse the OEM spacer/inserts as they are not included with silicone bushings.
katsue62
11-04-17 07:49 PM
SC300_704
Suspension and Brakes
12-26-08 06:20 AM
hyperopt
10-23-02 10:28 AM
