94 LS400 stalls when floored
Hello friends, when i try to floor or even accelerated to pass another vehicle my car stalls. It doesn't cut off but it hesitates and the engine light comes on and it seem to put put. Then when I let off the gas I can accelerated but only slowly. Help please!
OMAHA (07-10-19)
OMAHA (07-10-19)
This is what I've done for my fuel system....all preventive maintenance. Change spark plugs, wires, distributor, fuel filter, pcv valve..... run a fuel system cleaner thru it (SEA FOAM).... if you need a new CPU try finding one online and install yourself.... save a TON OF MONEY!
I don't know if the 94 LS400 is OBDII compliant but if not, at least on older Toyotas, jumpering TE1 and E1 on the diagnostic socket revealed the engine diagnostic 'blink codes' that correspond to the issue.
