where is the fuel pump on a 1996 lexus ls400
Why not just google it? Seriously its right there and so much quicker than creating an account only to ask that question. Cmon man
The fuel pumps are generally in the fuel tank behind the rear seat. Pull out the seat and remove the cover.
Yes, you'll find it on this site by searching. But a little more info quickly, since this is such a simple job:
Remove the lower rear seat (that you sit on). It is held in place with clips under the front edge. You'll just need to pull those clips out a little then the lower seat should pop up and out.
Then you'll see some bolts holding the upper part of the rear seat (that your back rests against) to the car. 4 bolts, I think, all down along the bottom edge of the seat. Remove those bolts, wiggle loose, and you can take out the upper part of the rear seat.
You'll then see, dead center, a circle of about 6" diameter. That's a cover for the fuel pump. About 8 screws around the circle hold it in place, and the fuel pump is on the other side.
EDIT - coincidence? If you look at the video in post #2 here:
https://www.clublexus.com/forums/ls-...ml#post9976356
at a little after the 1:00 part, you can see the circular fuel pump cover.
Yes, the fuel pump is in the tank.
