Rough Idle After Water
Old 09-21-17, 06:37 AM
  #31
Yamae
Yamae's Avatar
How much was the ripple voltage?
Old 09-21-17, 09:30 AM
  #32
Moarpower
Moarpower's Avatar
Not sure if you are trying to help me solve my issue or if you just want it to be ECU related. Unfortunately for me it is NOT ECU related as I have 2 other fully functioning ECUs. I have swapped in one of the 2 and the issue is still there. This is what happened when I had a faulty AFM. People telling me it was my ECU no matter what Id say. Replaced the AFM and all better. Sorry but the ECU is not always the culprit.
Please stop suggesting I check the ECU again as it really is just wasting my time at this point.
Old 09-21-17, 09:46 AM
  #33
Moarpower
Moarpower's Avatar
Again I have proven my own point here. People are too quick to jump on the ECU as the cause of the issues.
Replaced the passenger side ignition coil with a used one I had around and replaced the cats after i removed the inside of them. Problem is gone. Thanks.
Old 09-21-17, 02:57 PM
  #34
oldskewel
oldskewel's Avatar
Well you might be wasting lots of other peoples' time if you're giving information about your problem that is not accurate. You seem to have said that you did check the ripple voltage, and based on what you're saying recently, it seems there is maybe some doubt in that. I personally like to help people, but I also like to do it when I have accurate information, and have no interest when the information is intentionally inaccurate. As hard as you are finding it to solve the problem yourself, it is even harder for those of us who were trying based on inaccurate descriptions of the problem. Good luck fixing it. Sounds like you're onto it with the cats.
Old 09-21-17, 04:23 PM
  #35
Moarpower
Moarpower's Avatar
Oldskewel, I CLEARLY said I used an Oscilloscope to check the ECU and it was fine. That is a fact. My priority is fixing an issue with my car, so when someone gives me a tip I follow it and if its not the issue, I move on.. Im not counterproductive and have better things to do with my time than sit down at my pc to say I checked something, when I didn't. Especially when this thing could be the issue I am trying to fix..
Originally Posted by oldskewel
when the information is intentionally inaccurate. As hard as you are finding it to solve the problem yourself, it is even harder for those of us who were trying based on inaccurate descriptions of the problem..
What inaccurate descriptions are you talking about? How is any info I gave INTENTIONALLY inaccurate? Do you assume that I simply make up information for the hell of it? Thats is an interesting way to look at the words you read and its honestly a little insulting.
As for me wasting other peoples time. If I say I check something, and someone says "You didnt check it right" or tells me to check again, choosing not to accept that I already checked it, THEY ARE WASTING THEIR OWN TIME, not the other way around. Thats a fact mate. Im not a moron. I am a busy adult male with ****e that I need to get done.
Again, I proved my own point. If you read my previous post, I fixed it and it wasnt the ECU
inkredible
Performance & Maintenance
04-08-13 02:10 PM
durps
03-22-13 04:47 PM
ekrebs
03-12-08 06:26 PM
Pianoman72
GS - 1st Gen (1993-1997)
12
03-10-06 10:08 PM
t-mac
07-13-05 08:40 PM
Quick Reply: Rough Idle After Water
