Rough Idle After Water
Hey guys.
I degreased and hosed off my underbody near trans and engine to try to track the source of a leak and now it feels like my car is missing.
Idle seems ok in N and P but misses in D. While accelerating there is a clear miss. All plugs are new and firing. Im pretty sure this was caused by water as its too sudden an coincidental. Are there any sensors or connectors around the trans dipstick side that could cause this? Letting it dry tonight. Will spray some contact cleaner around tomorrow. Fingers crossed.
91 celsior
91 celsior
maybe you got an oxygen sensor wet somehow?
Likely that something got wet. The issue is still present after 2 days so I guess a sensor is damaged.
it is possible that this issue was present earlier as a slight knock ( or so I thought) while idling in drive . Now it is clearly running g rough and not firing on acceleration. It is idling fine in neutral.
Hey guys. Tomorrow I'll get under the car and start checking sensors. Any in particular that will make the car feel like its missing ?
I've had this problem before after cleaning the motor of my mom's 95... check the spark plug holes for water. I found water had gotten in the tubes and puddled around the spark plug shorting them out and causing the rough idle. You'd think with the caps this would not happen but it did. Once I remove the water and cleaned them up using compressed air to blow out the water, they did fine.
So I removed 3 leads and found some moisture on the coil plugs and the plug tubes. Let dry, the a little Co tact cleaner. Ran well for a few kms then started running g really rough and the cat warning light with Japanese writing came back. Maybe a sensor on the passenger side cat area was damaged?
Ill tighten it back up and pray but id say its damaged. May not be the issue but my guess is that it explains the light.
Cleaned the right hand side (drivers side) 02 sensor and installed it again. Idle seems better by a big margin, however, on acceleration between idle and 800rpm, whilst in drivem there is still a very rough rev range.
pulled off the rotor housings and there was no trace of moisture in either. It seems to take a few minutes of running to get really bad, feels like a restriction or like its not firing.
Seeing as the vehicle is a 90 model I will look into the price of new caps and o2 sensors regardless.
Could it also be a failing cat? Would that lead to similar symptoms? I do notice that the exhaust gets much hotter than it should and often creaks and crackles loudly for quite a while after shutting off the engine
