car won`t start.
car won`t start.
sc 400 1992
Opening the door with a key, an alarm came on, and the car won`t start.
The EIF does not have adequate voltage. for "1" pin only 9V for "2" the same as the battery. When I connect artificially sockets 1 and 2 (efi) everything works. Where does the tension go to slot # 1? With ignition or ecu? why did the car won`t start when the alarm turn on (I turned it off by turning the ignition switch)
I'm not sure if the SC400 alarm is the same as the LS400 but if you try unlocking the passenger door twice, (turning the key 2 times) it usually works. This happened with my 93 LS 3 times and it started right up afterwards.
DroppedGS
10-09-22 05:35 PM
