LS400 1st gen: heater not working
Old 10-19-17, 11:30 AM
OMAHA
OMAHA's Avatar
Originally Posted by YODAONE
Condition of Cabin Air Filter?
Check that cable to water control valve (on upper middle firewall) moves when heat is turned on...
I replaced with Lexus part and it does not move when i turn heat on..... but closes when i turn cold on.
Old 10-30-17, 10:12 PM
OMAHA
OMAHA's Avatar
The aftermarket hoses are leaking slightly.... mechanic told me the aftermarket hose should be in metric.....also i am not getting heat still, whether the water control valve is open or not....lol
Old 10-31-17, 04:00 AM
YODAONE
YODAONE's Avatar
The LS400 does not respond well to most aftermarket parts.
Highly unlikely that Javier at McGrath Lexus would recommend any of this...
Observe you are using worm gear clamps (overtorqued?) instead of OEM constant tension clamps. These parts store clamps are fixed inner diameter and so do not adequately expand/contract in order to maintain constant pressure/contact between hose and (plastic...) valve fittings with temperature fluctuation.
Constant pressure aftermarket clamps are available from more reputable truck parts stores for about $15 -$20 apiece.
Uninstall the non-metric thin-walled parts store hose and return to Lexus and order correct formed hoses (that do not kink at bends) before they fail.and overheat your engine.
Order also correct OEM hose clamps.
Aak someone knowledgeable, such as Toyota orr Lexus dealer, about products to clean up the red sediment build-up in your picture...
Old 10-31-17, 09:53 AM
OMAHA
OMAHA's Avatar
hey thanks.....Javier did not recommend to use aftermarket hose and clamps. That was my groundbreaking cost cutting move.....lol. I ordered hoses from Lexus this time and i will change the clamps.
Old 05-21-20, 08:07 AM
Idrus
Idrus's Avatar
Default Heater Valve broken
my have water out
BlackRX300
RX - 1st Gen (1999-2003)
33
11-19-21 06:38 PM
bigcat88
12-19-16 12:24 PM
Shado
02-11-16 06:50 AM
VIP161
Performance
11-25-13 06:20 PM
Quick Reply: LS400 1st gen: heater not working
