LS400 1st gen: heater not working
My heater went out recently. I can use my AC for cold air, however I can't get any hot air whatsoever! Whether I have the AC on or not, i cannot get any hot or even warm air. I have plenty of pink coolant in the radiator so that is not a issue. Does this look like a heater core issue or am i missing something?
Check that cable to water control valve (on upper middle firewall) moves when heat is turned on...
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20171010_184249_6e9bea500f625989a537d2285e585e5f3f5d6ab8.jpg)
Perhaps this is your problem?? LOL
Replace your water control valve all related preformed coolant, hoses and hose clamps...use OEM Lexus.
Be careful.when removing hoses connecting to firewall through-hole fittings...score the hose in several places to ease hose removal and avoid wrenching fittings.
This appears to be hard well water (high mineral content )build-up as a result of using tap water, and not distilled water, in the cooling system..
It should probably be professionally cleaned and flushed BEFORE next timing belt-water pump service.
Replaced a water control valve on a 1993 LS400.
which was experiencing an elusive slow coolant leak...
Zero build-up, so the only way I was able to confirm this was tte source of the leak was to wrap a paper towel around the valve and wait for coolant stains to sppear...and they did...problem solved..
Due to mileage and age of internal rubber seals, probably a majority of water control valves on 1990-1994 LS400's should be inspected for leakss.
Corrosion??
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20171019_115442_9c31f26ffafe52278b44eeb07462c777c30e3819.jpg)
A issue has arose.....the valve will CLOSE when i turn it to COLD but when i turn it to HOT it stays CLOSED. I can manually OPEN it though. Mechanic says i can open it during winter for hot air or close it in summer for cold air. My question is.... is anyone familiar with what is going on now?....LOL
