Air Bags System Setup
Hey guys,
Bought a set of used BC coil and UAS bags setup over the weekend. It came off a 96. would it fit on my 94? Looking to buy a low budget manual air system. Any suggestions on where I can find them? Not exactly sure what I need to complete a sir system. First timer with an air system.
BC w/ UAS bags
94 LS400
BC w/ UAS bags
94 LS400
yep they should fit however you may need to adjust the lower perches on the coilovers to dial in the ride height.
have you done any suspension work before? if not I highly suggest seeking professional help as it's more on the advanced side of suspension installation.
go to bagriders for your manual valve setups! of course you'll need the tank, air compressors, and lines to complete.
https://www.bagriders.com/manual-paddle-valve-kit.html
I thought "Air Bags" where those things behind the steering wheel that pop out and are supposed to protect your face.
Maybe these things your talking about are Air struts, or Air suspension? Sorry I get confused at my age with so many air bags around.
read:
https://www.clublexus.com/forums/ls-...tup-ucf20.html
haha yes those are air bags too, but in this case they are air suspension related. see my link above if curious how to set one up!
