93 ls400 speed sensor problem
Car runs perfectly fine nothing off at all shifts fine runs strong has to be wiring issue but short of gasoline and a lighter and I won't have to worry about it anymore lol
Update:
Went to 2 electromechanics and they didn't do ****. No one wanted to touch the car now except 1 that told me to bring it before closing to leave it and the can check it during the week
The speed signal is also sent to the ABS computer. There might be a possibility that the speed signal is eaten by that and the amplitude is less than the threshold level at the cluster unit.
I'm debating on picking up an abs computer today thought I remember a while ago my abs went crazy for a couple days then back to normal guess I need to hit a gravel road to check the abs lol
I haven't given an update yet cause around here NO ONE wants to touch the car. Found 1 shop that told me 100% bring it but it has to be tuesday and up, let's hope it goes well.
If you dont ever get it fixed buy a GPS unit and use it for speedo.
Thing is it rides like bullocks, tranny doesn't seem to know when or how to shift and in Park or neutral engine revs up great but in gear it's extremely lousy. I'm guessing it's in limp mode because the speed sensor signal is not reaching the ECU or anything thus the car not knowing how fast you are going.
Update:
Mechanic called, he tested the wave with a oscilloscope and no signal whatsoever. He found a way to make it send a signal but cluster doesn't work then.
Extremely weird. Hope Yamae can fish in on why no wave signal is being generated
