94 LS 400 Radio issues
Haven't done an LS. I do know the "premium" radio in the Camry has an amp behind the glove box that powers the speakers independent from the head unit. I had to use a different kind of hook up from an aftermarket radio that let me plug into the line-level RCA out plugs on the back of the radio and click that into the harness that goes to the premium amp. Trying to connect directly from the amplified outputs does not work unless you chop up a bunch of wires and try to bypass the amp entirely.
amp is under the pass side seat. it powers all speakers and sub so it will need input from the HU properly.
see thread below:
https://www.clublexus.com/forums/ls-...er-thread.html
see thread below:
see thread below:
see thread below:
Attached is the wiring diagram for the 1994 LS400 Nakamichi system.
blubox (04-21-24)
kpkim01
03-05-12 08:19 AM
