Fan/Fan Clutch/Bracket noise
developed this noise, and it has gotten worse over time. I replaced the fan bracket with a cheapo chinese one when i did the timing belt/wp job. I kept the original fan clutch in there. Not sure how often they go bad. Any ideas on which it could be?
Thanks in advance!
Thanks in advance!
Scraape (10-26-17)
i replaced those items as part of the 90k maintenance, so i would hope they haven't gone bad yet. But ill look into it
Scraape (10-26-17)
i already did the 90k maintenance. Replaced mostly everything. I overlooked the serpentine belt tensioner pulley bearing thing though. The bearing itself seems fine. The metal piece in the middle of the bearing that is supposed to spin was making the noise. I put wd40 on it and it doesn't make the noise anymore.
update : it was the serpentine belt tensioner pulley bearing. I will replace the idler pulley bearing as well when i get the chance, but the noise is now gone
A friend of mine seems to think there are two bearings in the top idler bearing, is that the case?
These should definitely be replaced as part of the 90k maintenance, or every 180k maybe
