Vibration at 180p rpm
Losiracer2, I replaced the aftermarket engine mounts with the genuine Toyota/Lexus mounts and I am still getting the vibration. It is a very slight vibration that I feel on my seat while driving at all speeds. I also feel it while in park but it is more pronounced at 1800 rpm.
What could be the cause.of this vibration? Note that engine mounts and transmission mount were replaced.
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/872848-transmission-crossmember.html
I've had 3 SC300's, (still have a 99 SC3) and 2 SC400's. Guess which ones I was always chasing down vibrations in? Yep the SC400's. The 92 I just gave up, but with my 97 I could fix it and then shortly after another vibration issue would come up. Owning an old Toyota can be very frustrating sometimes but when the planets align and everything is working right, you just can't beat it! Good luck and I hope you solve the problem soon to your satisfaction. You sound like a ride snob like me haha. I was going to suggest checking the flex disks on the drive shaft until you said you can feel it even in park. Knock on wood my LS400 is silky smooth for now.
RXGS
11-18-11 05:47 PM
