1998 UCF20 Celsior Cruise Control Delimiter
Old 10-29-17, 11:59 AM
danzafar
danzafar's Avatar
Default 1998 UCF20 Celsior Cruise Control Delimiter
My 1998 JDM Celsior has a limiter that doesn't allow the cruise control to be engaged at speeds exceeding 108 km/h. I've found instruction to have this disabled (http://planetsoarer.com/cruise/index.htm), but I'm not sure how valid this is. Any one here with a Celsior done the same thing? Thank you.
Attached Thumbnails 1998 UCF20 Celsior Cruise Control Delimiter-img_2369.jpg   1998 UCF20 Celsior Cruise Control Delimiter-img_2382.jpg
Old 10-29-17, 01:09 PM
creilly
creilly's Avatar
Hey! I know this one! I had to do this on my 1991, so I'm not too sure if the location and procedure is the same for your 1998, but that is exactly the method I used to delimit my cruise control. Locating and removing the cruise control module is a bit of a pain given the small amount of space, but it's pretty straightforward. Cutting the jumper is a precise operation but it's not too hard to break that connection, just make sure you have strong scissors or something similar.
In your case I'd try to find a photo of the cruise control module from a 1998 LS400 and see how it's different from yours. That J1 jumper is the only difference between the Celsior unit and what came on an LS400, so it stands to reason the same would hold true for your later car.
Old 10-29-17, 03:47 PM
danzafar
danzafar's Avatar
Hey! THANK you so much for confirming this - I just wanted to make sure this was legit. Did you disconnect the battery before doing this, or pretty safe to do so without the disconnection?
Thanks again!
Old 10-30-17, 11:13 AM
creilly
creilly's Avatar
I didn't actually think to disconnect the battery before doing mine... clearly I lived to tell the tale with no ill effects but disconnecting the battery only takes a second and it's an easy way of ensuring you don't get a nasty shock or worse.
Old 11-01-17, 04:35 PM
danzafar
danzafar's Avatar
Hey again. Please help! The circuit board in the cruise box of my 1998 look nothing like the instruction
Old 11-01-17, 06:36 PM
creilly
creilly's Avatar
I can't offer much since I don't have access to a later cruise control module. Maybe you could get an LS400 cruise control module and try to swap the boards? I'm not familiar with the way the system is set up on the later cars. Hopefully someone else here might be able to shed some light on this, or post a picture of the 98-00 cruise control board for comparison's sake.
Old 11-01-17, 07:10 PM
danzafar
danzafar's Avatar
Thanks man! I put everything back together and, for the time being, breathed a sigh of relief for not mucking anything up. I'll live with what I got!
sparky2708
RX - 4th Gen (2016-2022)
15
12-26-22 06:22 PM
villamora
07-16-17 10:28 AM
brn2rnjk1
11-06-05 08:00 AM
Quick Reply: 1998 UCF20 Celsior Cruise Control Delimiter
