Fuel gauge not moving
So I bought my 98 lexus this past Friday. The dealership filled it up before I left. I've driven it aboit 100 miles and the gas gauge has not moved yet. The dte has gone down about the same amount of miles as are on my trip meter but the needle on the actual fuel gauge has not moved. Is that odd or normal for these? Could it be my fuel pump?
It won't be the pump and the pump doesn't send the fuel level. Some cars will fill further than than gauge and take a while to come down but 100 miles seems a bit much. Could be the fuel level sender in the tank is stuck. Is just call the dealer
yea im going to try to get someone to look at it. it actually moved down a little bit on the way into work this morning. go figure. it still seems like it should be further down. ive heard these things have big tanks but this is kinda crazy
so since it has started moving, my dte gauge now just says "low fuel". my gas light came on a little above quarter tank according to the needle. is that usually when the gas light comes on in these cars, or is my needle probably a little off? the gauge seems to still be going down but it seems to have slowed a little bit. any insight would be awesome.
thanks,
-Sean
thanks,
-Sean
Post a picture of the cluster/needles with the car off and we can tell you what the problem is
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
