Engine Cover Splash Shield ( underneath engine )
#31
#32
#34
Has anyone been able to confirm if a shield for a 95-97 will work on a 98 LS400? Ive checked ebay and amazon and cant seem to find any for a 98 LS400. but there are plenty for sale for 95-97 model years.
thanks
thanks
#35
I've got one on my 98. Not all the screw holes line up, but most of them do. You might have to drill a hole or two, but you can make it work.
#36
#37
I need to get a replacement one too. Anyone seen the Ebay ad for a Genuine Toyota one for $80?? I messaged the seller if it was the correct part and will see what they say. A few bucks more for factory one doesn't hurt.
#38
is it for a 98-00 Ls400 ? if so i missed that ad on ebay. would you mind posting a link to it.
#39
https://www.ebay.com/itm/1995-1998-L....c100667.m2042
#40
It's for 95-early 98 models. From what I read, it should fit but you will have to cut different holes. I just ordered one....$89.64 including tax and s/h.
thanks for the link. Here is the one i ordered. It looks identical to the one you bought. Please update if you can how yours works out. Ill try to do the same. Good Luck.
https://www.ebay.com/itm/New-Front-F...72.m2749.l2649
#41
Once I replace mine, I will definitely give an update.
#42
I got mine installed this evening. Took about 20 mins to install. It fits very nicely. I did not have to modify the shield at all. I ended up mounting it in the rear with 2 screws and used the 5 or so screws in the front to mount under bumper.
JMLS (12-08-19)
#43
Are you sure that's not upside down?
#44
