Have a 1991 LS400 with 67000 miles. Trac off and Check Engine lights come on. What does this mean????
Start by reading the codes. If you get a 25 / 26 code off the check engine light, replace your oxygen sensors and the Trac Off light often will magically go out never to bother you again.
Colin
Do you really only have 67,000 miles? That makes two of us)
The timing belt and water pump have been replaced. Where do I get a code reader? And yes only 67000 miles from brand new in 1991. Have replaced two of the four oxygen sensors--the easy ones.
Then we need to start with Last Thing Done To Engine. Were these sensors "upstream" or "downstream" of the catalytic converters? Did you have to splice or did the new sensors come as plug n play? If there was splicing involved, you will want to check the work performed, and do not overlook the possibility that new sensors can go bad.
The codes I grabbed out of my memory banks IIRC were for upstream sensors.
Colin
