Whirring noise
Old 11-27-17, 11:15 PM
Xeros1313
Xeros1313's Avatar
Default Whirring noise
So my 95 ls400 was K.O.'d for about 3 months and I had to replace the air compressor and starter. Unfortunately the compressor purchase was broken so we omited it. The start just got put on today and I drove it to the local Jack in the box around the corner, when I got home and killed the car it was making a whirring noise, I was like "whatever" so I tried starting the car back up and it wouldn't click or grind or anything. Now I'm thinking the batterys dead after sitting for a bit but the lights and everything work just fine. I need help.
Old 11-28-17, 02:15 AM
Moarpower
Moarpower's Avatar
Sounds like your starter was stuck on. The solenoid might have had it. If it was while the engine was running it could be a pulley.
Old 11-28-17, 02:19 AM
Xeros1313
Xeros1313's Avatar
after hours of research and what not I found out that it's a 50/50 chance that it's the battery or the starter solenoid. When daylight comes around in a few hours I'll go outside and tap the starter a few times and if that doesn't work I'll test the battery.
Old 11-28-17, 02:24 AM
billydpowe
billydpowe's Avatar
Yep, I dont understand all your post, but you need to take the starter back off and test it OR have it tested.. I agree the solenoid might have stuck in the flywheel.
Old 11-28-17, 02:38 AM
Moarpower
Moarpower's Avatar
Can you get to the starter to tap it ? I thought it was pretty well out of the way.
Old 11-28-17, 03:17 AM
Xeros1313
Xeros1313's Avatar
oh it's way down there. In the intake manifold but with a long enough screw driver I should be able to reach it
Old 11-28-17, 03:59 AM
Moarpower
Moarpower's Avatar
New or used starter?
Baby ///M3
Performance & Maintenance
12-02-23 03:53 PM
guzzy92fs
10-02-23 12:29 AM
Liybzd
06-27-19 09:47 AM
BillBurns
09-19-13 09:13 AM
wyciwug
RX - 1st Gen (1999-2003)
04-16-10 02:44 PM
Quick Reply: Whirring noise
