Timing belt and water pump replacement?
My 1993 LS400 is right at 160K and just started leaking radiator fluid and sounds like the water pump broke. It also has been leaking oil from the valve cover gaskets. Should I perform the recommended Lexus 160K replacement maintenance cycle for timing belt/gear at the same time. I know this sounds like a redundant question, but it also doubles the cost. How long does the timing belt/gear actually last? It was last replaced at 80K in 2007. Thx, K.
sarah
RX - 1st Gen (1999-2003)
13
02-04-15 03:13 PM
