Ls430 engine cover on ls400?
Series 1990-1997 LS400 will.require 100 % bracket fabrication....provided there is necessary engine compartment clearance for an LS430 engine cover.
On an interim basis you could borrow or inexpensively acquire an engine cover from 1998 -2000 LS400 to check approximate fitment...
A pick n pull yard may have an inexpensive LS430 cover, but less likely. You will require all 4 engine cover mounting brackets.
you need a car that breaks down more often, the LS is too reliable so you keep getting bored and thinking of these side projects to do lol
i mean seriously... the amount of noise difference made by changing the engine cover might be noticeable if the hood is open and your ear is right next to the manifold, but will be completely indistinguishable while you're driving
also now your car is dishonest going around saying 4.3 on it
The LS430 parts bin has provided inspiration for several engineered upgrades for our LS400; 130A hairpin Alternator, the water inlet housing, improved sound damping and sound attenuating upgrades
Numerous sound and vibration. attenuating upgrades evolved the LS430.
Some upgrades are more incremental than others, but ultimately add up to what distinguished this automobile from most others of their time.
On this forum encounter "why didn't the factory do that?", so applying and presenting ideas that the factory adopted focuses attention on the improvement at hand.
Haven't decided how to handle engine cover badging....eithet install a 3UZ-FE engine or remove the raised 4.3. ...
This is but one of the sound/vibration attenuating items Toyota employed in the LS series evolution.
I already answered this for myself and will probably employ a Dremel to remove and then buff out the badge. Maybe a heat gun and tinfoil to add back texture if necessary.
But I like your solution of the 3U-FE swap. Much more practical.
Yes.
Tthe LS430 cover does not have a center cutout, so no longer hear the intake there.
The underside of the LS430 cover is more fully covered with sound absorbing material...and it is a heavier and more rigid cover..it feels like damping panels topside.
The LS430 cover dispenses with the two rear fasteners by substituting rubber ball and spring clip socket (under cover) to further dampen.
In comparison, the LS400 cover just resonates.
The LS430 cover is a more effective sound barrier/absorber...and engine vibration damping component.
It is best practice to isolate noise and, or, vibration as close to the source as possible.
With an engine as smooth and quiet as the 1UZ-FE, undistinguishable noises on other vehicles, are readily discerned on the LS400.
Our fuel injectors generate considerable noise...and am working on ways to more fully sound isolate at the source..
Once you quiet one thing, another's sound appears.
The LS430 cover design provides space underneath which directs airflow over the top of the intake manifold, instead of blocking it....so cooling is enhanced.
To put the ribbon on the package, am considering painting the silver colored portion of the cover with body color paint. and clear coat .
Mine is jade pearl.siver so won't have to endure space man silver...but first have to sort out whether Automotive touch-up brand paint is compatible with the plastic cover.
If anyone is curious I just measured the decibel at idle with the cover off vs with the cover on (LS430). The car idles 3db quieter from a foot off of the engine with the cover on.
DaveGS4 (04-18-19)
Painting engine cover body color
https://www.clublexus.com/forums/ls-...ne-covers.html
Not sure what I'm going to do with spare LS430 engine cover
Cover in transition to Jade Pearl Silver. Center section is masked and clear coat to be applied
pinoy_islander
05-23-06 12:19 AM
