Rough Idle After Muffler Delete
Hey everyone,
New to the page, and a bummer I'm introducing myself under these circumstances..
Yesterday I cut off my 4 mufflers on the car so I could really hear the engine, and I did not remove any cats or (to my knowledge) O2 sensors. The car is not giving me any check engine lights but it developed the issue where it will misfire and "sputter" at low RPM. When braking and coming to a stop the car literally bucks back and forth from the inconsistency in the "Bang" portion of the cycle. I'm not sure if just welding in a full exhaust from where I cut the original will help, or if it is a bigger issue. Again, no check engine lights (yet) but it loses power when accelerating in the low RPMS. Could cutting the exhaust have altered something to do with the way the ecu reads the ignition or air/fuel ratio?
Please help!!!
Please help!!!
Hey everyone,
Please help!!!
Please help!!!
Simplest thing you could do is unplug the negative battery terminal for like 15 min and plug it back in and drive around and see if there's any difference
Okay Scraape, I'll give that a shot. Just based on the way it was acting it seems like for of a fuel mixture issues, so resetting the ECU so to speak may fix it.
Thanks!
I'll keep you posted
Thanks!
I've done a muffler delete but only the rear mufflers not the inner two with no problems. of course you'll experience a lack of backpressure which will equate to a loss in power (hard to tell from the seat) but it should in theory not affect the way the engine runs as you only altered the parts after the secondary o2s.
an ECU reset is a good idea to start. I would definitely consider extending the pipe to the rear of the car not only to restore a little bit of the backpressure but also to vent the exhaust away from the cabin. that stuff is just a tad toxic !
Thanks for the advice guys,
Unfortunately resetting the ECU didn't yield any good results. Thinking that I definitely need to follow the exhaust out the back, as well as check for vac leaks and check my coil packs. These are really the only things that seem logical to me as being the source of my issue.
The misfiring appears to be intermittent, but becoming more apparent after the engine is warmed up. At first it seemed to be doing it only at idle, and now it misfires almost constantly through the rev range.
Any other ideas?
Thanks
Any other ideas?
Thanks
Wait...did you literally just cut the exhaust before before the mufflers?? Did you not ad pipe to those sections? If you just deleted it at the first muffler set it will run like **** mate.
