new 98 ls owner needs some wiring help
hi guys/gals! i just bought a 98 ls and need a hand. the connector on the tps sensor on the right side of the throttle body is broken and i need to know which color wire goes in what pin in the connector. if someone could snap a pic of the connector clearly showing the wires color where the wires go to the connector i would really appreciate it. this is the last thing i need to fix to get it driving! thanks!
Check out this thread... particularly 10.2
https://www.clublexus.com/forums/build-threads/754842-how-to-wire-up-a-1uz-engine-vvti-and-non-vvti.html
Useful information...
Connect Shell P.N.s.
If you require contacts, call Lexus for P.N.
The contact pins release from connector shell by depressing lance.
If not comfortable with extracting contacts, then have an electronic tech assist you...
GRAND_LS 4
65
04-14-18 07:58 AM
Jasoneo5
05-12-03 02:09 PM
