vibrating / resonating noise after suspension movement '99
Hey guys,
I've got a vibrating / resonating noise assumable from the rear, triggered by suspension movement. This can occur at road imperfections and sometimes if there is a "smooth bump" in the road.
It feels like it is not during any movement, but more like it get triggered by it and the sound stays no longer then 1 second unless triggered again.
Has anyone had this before? I couldn't find anything like it just yet.
I haven't been able to have a look underneath just yet, but I have lifted all wheels from the ground. I did notice a little play in the rear wheels moving them up and down, but not moving them sideways. Thing is though, I believe I have felt this the last time I did a check on the car but the current issue started recently.
Sound familiar to anyone?
Thanks
Thanks
Had a look underneath the car, couldn't see any odd things.
I did notice that around 50mph the sound / feeling is somewhere in the background (on higher speeds I can no longer hear it because of other noise) and intensifies on bumps in the roads like I described on my first post.
I do not here anything weird at 20 though
Hey guys,
Thanks
Thanks
Colin
Well I can't really say how much hertz the sound is no. I have never heard of such a question before..
And yes, it is really hard to describe. I believe I have heard a resonance before that came close, and that was a rear hatch that wasn't closed properly. Thats the closest I think I can get about the sound it self. It is a low drone but that's all I have to describe.
I'm also not sure if a microphone can pick it up while driving.
OsLS400 (01-24-18)
I have the same “drone” sound as well. I have read in other post about such noises and the final response was “turn the radio up” . Since I don’t have a lot of coin that’s been my remedy. But if somebody has an answer my interest is peaked.
Have to be honest, the dealer stated upon a multipoint that I absolutely needed LCA bushings. So I bought them and had a indie install. Indie said they doubted I would feel any difference, and I did not. I was one of the people (I'm not the only one but we seem to be the minority) who saw zero benefit to the change, even though they were visibly cracked. Not the end of the world as they are a physical wear item, cost at the time $130 on eBay for OE, and I paid around $290 labor. So no big deal,
If I were a betting man I would guess they would not solve your steering issue, UNLESS these are torn--there are YouTubes where on Maximas, a person grabs the arm and moves it by hand--there the bushing replacement will absolutely correct a problem....point being even when the dealer said my bushings were shot, my steering had zero movement/play. There have to be a ton of rubber items, tie rods, ball joints, etc. that could cause an issue...good luck!
I slapped snow tires on my car inside of 2 mos. of getting it, then noticed an annoying and loud drone...convinced myself it was the rear diff. It really turned out to be the tires. I just didn't know my car well enough before putting the loud snows on....maybe tire related?
