starter motor keeps cranking
Old 01-13-18, 11:43 AM
oldskewel
oldskewel's Avatar
Originally Posted by fixmiester
This is NOT true , the starter does not continue cranking when the key is released. You simply have a fused solenoid; no need to pull the fusable link, just accept that the solenoid is bad. Solenoids and relays are exactly the same thing; one is designed for only a few amps of current, the other for hundreds of amps, that's all. The starter relay simply provides current to the solenoid's coil. The 98-2000 400s aren't quite as bad to fix as the earlier models, since there is no EGR plumbing.
You are right. Sorry about that. I must have been confused with one of my other cars, but I could have sworn ...
I have a copy of the owner's manual right near my desk so I looked it up. Page 99 says, "...crank the engine by turning the key to "START". Release it when the engine starts." Pretty simple.
So that's good news for swan55, since it mean the system is not complicated by this feature.
I'll go back and edit my previous post so nobody reads that without finding this correction.
Old 01-13-18, 01:01 PM
oldskewel
oldskewel's Avatar
Here's a scan of the circuit (for my '91, no promises beyond that) with the battery, fusible links, starter relay, starter, etc.
So you can see what gets shut off by pulling the starter relay, fusible links, etc.
It looks to me like pulling the 120A fusible link is not the only thing needed, but it would take care of most other possibilities.
lexus battery circuit.pdf
swan55 (01-23-18)
supra9398
Performance & Maintenance
04-27-17 11:15 AM
edinburger
11-29-13 10:06 AM
bjjenkin
12
09-12-10 06:09 PM
gtfour43
07-06-05 11:54 PM
airahcaz
Performance
04-25-03 01:19 PM
Quick Reply: starter motor keeps cranking
