1999 LS400 Climate Control Bulb PN
My climate control unit (non-nav) air recirc and AC button back lighting decided to stop working. Does anyone have the correct part number for the bulb I need to replace?
This is not the indicator LED (indicating whether the ac is on or not) but the back lighting for the button itself. Not looking to replace with LED, would rather keep it factory.
Black base P.N. 90010-03013
White base P.N. 90010-03012
Replace all while you are in there
Climate control amplifier has eleven 47uF 35V capacitors....replace them with 47uF 63V...
Same case size.(higher voltage is improvement)
New capacitors in 35V range are more efficient, thus smaller case size and lead centers, so went higher voltage for fitment and performance.
All ten capacitors same value...
If not familiar with soldering, or anti-static precautions, then have a tech.perform.work
A link to previous write-up
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/855424-1995-2000-ls400-climate-control-capacitors-and-backlighting.html
When accessing climate control, Be very careful when extracting center vent....old plastic parts like to break off.... $$$ part.
pay someone $20 with correct tools to do.
CELSI0R (12-10-23)
Thank you Yoda!
Just as an FYI I contacted Tanin ( I understand you are not a fan of them, but I have had nothing but good experiences) and they have sent me all 10 bulbs for $15 shipped. Lets see what arrives. If they are OEM then they will be cheaper than going through the dealer.
I don't quite understand why you replaced the caps.
Thank you Yoda!
What about color filters??
bulbs made in China?
OEM are Japanese....
The OEM uses two bulb types...
Perhaps there is a reason for this, and rarely do I find aftermarket anything to standard...
Since you found it necessary to mention my sentiments, and I went through time and effort to help direct you with correct OEM part usage (which you requesred), and others similarly situated, please, kindly indulge us on what part numbers then the vendor provided..
Perhaps you can provide images of said parts...
Thanks
I hate to say it, but the Toshiba bulbs that Toyota uses are a lot brighter than something you'd find either at Radioshack or aftermarket at Orielly or Autozone. Not to mention the bulb form might be different and not fit into the socket, so be weary of that.
I noticed this both on my parents 2003 Toyota Sienna and my LS400. I ended up buying a used GS300 radio for $30 and had to unsolder those bulbs and solder them onto the circuit board of my LS400's non-nakamichi setup.
I represented German manufacturer ALBA who was a primary supplier of instrument and dash bulbs to Mercedes-Benz.
Thank you Yoda!
There is no purpose in replacing the caps or the bases. Those can be reused. The button lights are the black based bulbs. The screen backlighting are the white based bulbs. The white base bulbs are around 0.20mA more than the black base bulbs. Our bulbs are a near identical match to the black based button bulbs.
Can you leave your white based bulbs alone? Probably. Will you notice a difference if you replace the white base bulbs without ours? Probably not. Are they an exact match to the exact mA of the white based bulbs? No. Are you going to look at the climate control in the dark and say, "hmm the screen lighting appears to be 0.20mA dimmer than the button lights". Come on now.
Are you a perfectionist and don't mind spending more? Go with OEM then. Nothing can match OEM. We don't usually sell anything OEM because anyone can buy OEM parts at the same price we can.
Bottom line: are you looking for a quality replacement at a lower price? That's why we are in business.
There are a lot of variables involved here. I can answer them in more detail if needed.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
__________________
262-456-4147
262-456-4147
I wonder whether a 12V bulb would glow, if at all, in an 8V circuit....but it sure would last a long time!
If relamping with non-OEM bulbs then best to take voltage readings.
Color uniformity between OEM Pioneer radio backlight and factory climate control backlighting is remarkable....
Someone spent a lot of time getting it right...
The green Silikrome incandescent lamp color filters on climate control bulbs are high grade silicone rubber with a 25 year shelf life...
Several submiature incandescent bulb vendors are no longer in the business....
__________________
262-456-4147
262-456-4147
YODAONE
05-04-17 07:16 PM
RastaPasta
10-02-12 07:20 PM
John U
12-15-08 05:24 PM
