91 LS 400 strange problem starting
My 91 LS 400 has 150k miles on it - runs beautifully but has developed a starting quirk/issue???
Overnight, it went from a nice normal fairly quick crank/start to a long crank start.
After a day or two of this, I discovered that if I turn on the key for a quick (about 1 second) crank then off, then start it again, it cranks right up.
This is pretty much hot or cold...
Any ideas would be much appreciated.
As an aside, I have a 2001 Dodge Ram 1500 than developed the exact same symptoms, overnight.
/Don
/Don
/Don
/Don
IF the above symptom was noted only when cold, I would question the cold start valve circuit. Otherwise, warm and cold:
a) leaky injector
b) leaky check valve at pump or regulator
Colin
Thank you. Colin - Hot/cold - makes not difference. One quick crank, then off, then next crank, it cranks right up.
I'm guessing the fuel pump check valve is part of the fuel pump itself?
Is there a check valve at the pressure regulator, or is that itself possibly the culprit?
Thanks so much for taking the time to respond.
I will check these out.
/Don
/Don
winner155
24
02-15-12 05:13 PM
