rpm gauge not working
my rpm gauge doesn't work when the car is running,it lights up moves to the right when i start it ,and it also lets me set it when it reaches a curtain rpm.
i also replaced it with other cluster and it does the same rpm not working ..i have no warning lights and everything works but rpm?/?????
what car is this for? year? mileage?
based on a quick background check on CL you have a 06 is250...so this would be the wrong forum to ask but I want to help as I have an 07 is250.
sounds like the signal for the tachometer is lost. it moves indicating the cluster itself is not to blame (it does a full sweep of the needles on startup) plus you confirmed this by swapping clusters. was there engine work done recently? most likely something was unplugged or broken.
I cleaned out my IACV. Initially, it solved the stalling problem, the problem returned a month later. I recleaned it, and now I notice the RPMs have dropped from 600 to 500. If it's not the IACV, what might be causing such a low RPM?
mclarenf1k
Performance & Maintenance
02-24-10 10:26 AM
