95 ls400 seals.
95 ls400 seals.
Hi everyone.
does anyone here know the part numbers for the front and rear cam seals and the front crankshaft seal, and timing belt and valve cover gaskets?
my 95 LS400 started leaking oil pretty bad a week after I had the thermostat repaired by a Toyota dealer. I took it back in there and they told me that all these seals needed to be replaced. I had just had the timing belt and water pump done about a year ago, and now because it's leaking oil I believe I have to replace the timing belt also. The car runs great I've never had any problems with it. It's got a hundred and twenty one thousand miles on it never leaked a bit of oil, and now this. I have someone that can help me work on it but I need to get the part numbers for the seal kits and all. If anybody has that information for me I'd appreciate it. Thanks guys.
Hi everyone.
My Crank seal also failed causing me to do the timing belt service around 255k. I bought a Toyota crank seal and used Fel Pro cam seals (also made in Japan) since they were on closeout for $2 a piece.
paulv85
13
05-05-14 07:51 AM
