Grill ?
Re: grill
Originally posted by Lexkost
You can take a Trenz Grill and remove every other bar and end up with 8 bars and it looks better than new.
Lexkost - that is a gorgeous grill. I went to their website, but can't find a grill for a '91. Wouldn't it be the same as the '92? Does anyone know, or have info. on any other grills that would replace that lame grill that is OEM on the '91 LS400?
Originally posted by Wide LS
How did you remove every other bar? All the bars are welded on mine
O.C. Lucky Strike Fanatic
I used my grinder with a 1/32 wheel to cut them out and had to be very careful not to hit the good bars.Then I used a dremmel to clean up and then repainted it black and repolished the front.....about a 3 hour job.............This was the same grill you have.....
Thanks
