Sealed lower ball joint,why not add a zerk fitting?
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Im reading these posts and complaints of not being able to grease LBJ's. My Dad,when sealed bearings first came out,drilled a hole in the back and added a zerk fitting.Then when he did chassis lube he would carefully lube thru the zerk being careful to not expand the boot,and smooshed out the old grease from around the boot.
Couldnt that be done on the Lexus? Any thoughts or am I all wet on this idea?
My original Lexus LBJs were still greased when I replaced them due to wear back in 2015 on my 97.
I replaced them due to slop, not due to lack of lubrication. Even the rubber boots were still intact.
If you add a greaseable fitting, there is a tendency to overgrease them and blow out the boot and cause a failure
The biggest issue with adding zerk fittings to a ball joint that wasn't designed for it is that you'll blow the seals on the boots when you go to grease it as unlike a greasable boot it's usually a total seal in "permanent" applications.
So the top of the boot,on the shaft,is sealed and cant allow any grease to be pressed out between rubber and shaft?
Lexus cars, however, seem a lot easier to replace than the ones I try to make last forever on air-cooled Volkswagens, and I would replace and zerk the new one considering that there have been too many recalls on Toyota/Lexus lower ball joints:
https://www.consumeraffairs.com/news...ll_joints.html
www.arfc.org/autos/lexus/gs300/recalls.aspx
https://repairpal.com/toyota-recall-...oint-issue-677
OMAHA
12-19-14 12:45 AM
kit cat
06-15-07 02:25 PM
