nakamchi tweeter replacement
i am working on my ls400 as i can.
when i got the car it was 100% stock. when i mod a car i do everything i can to make stuff bolt in and make it look like factory. my ls has the nakamichi system. 7 speakers and only 3 sort of work. the sub works, one tweeter and one rear door speaker. f
rear doors:
boston acoustic S45 $Free from a friend
installation: these went in pretty easy. heated the back of the speaker box with a heat gun and pushed the back out a little so the speaker did not hit the bottom.
front doors:
tweeter: DAYTON ND20FB-4
its a rear mount 3/4" soft dome with good reviews $14.20 each
installation: pretty straight forward. removed the stock tweeter from the bracket. then used a die grinder to open up the stock tweeter bracket to accept the tweeter.. tweeter has four holes for mounting that work with the factory bracket.
so far:
rears sound decent for 4" speakers...the new front front tweeters are ok. i thought they would be brighter. i am playing with the crossover points and the 4" woofer in the door still. as i work on this and finalize the system i will update this thread.
rear doors:
front doors:
so far:
fst4dr91
07-16-11 10:03 AM
BananaGS
08-05-01 10:34 AM
