Need to replace trunk lift supports on 2000 LS 400...
And am only finding one aftermarket source, which is Lift Support Depot sold by amazon.com, newegg.com, etc. All seem priced at $60 per pair.
Anybody used these or have other sources for these lift supports?
Thanks,
Eddie
Thanks,
Eddie
Thanks billy.
No idea how many times my trunk has been opened/closed as I just bought it last week. It will stay open if all the way up, but will close if at any point below fully open.
I assumed (I know, I know) that it should work like the hood and stay open when placed partly open. And it certainly would not take much for it to close one someone's head.
I think I'll just spend the $60 to make sure it's as right as it can be.
Thanks again,
Eddie
Thanks again,
Eddie
It will not push itself up into the full-up position like the hood does, but that's a different situation. The hood cannot go straight up, so it needs the strut to push it. Not so with the trunk.
Super Moderator
We've had ours since 59K miles and the trunk operation same now as back then. Full open or closed, it will not remain partially open by itself. Unlikely that the lifts need to be changed.
Same with hood. With both (fresh) lifts installed it will push the hood up. As the lifts age they lose some of their pressure to raise the hood yet in full open they will keep the hood up. Any place below and they will close.
Mine can only go down from open maybe 10%.So might be a little tired but works fine full open so Im good I reckon.
EmpPenguin
13
11-18-13 09:50 AM
