Does anyone have a picture of how the ECU for a LS400 1993 is positioned under the dash of the passenger side?
I should have taken a picture before removing.
Thanks.
The connector loom will have a particular bend/set and the ECU will plug in based on that. If you have to turn the connector it is not in the right position in most cases and will not align to the bolt holes.
