steering column wont go up and down 1999 ls400
steering column wont go up and down, only forward and back. is it my model that doesnt have this feature
Remove the plastic under the column. Apply a little grease to the area circled in red. There are also 2 small plastic bushings, one for tilt and one for tele, they are cheap and fairly easy to replace. Once you have the plastic shroud removed from the column you will have a much better idea waht's actually going on...
the 99's are a bear to fix.. search to find out how to do it , cost about 100$ and sending it to Chicago..
my 99 has the same issue. Previous owner unplugged the motors altogether (I will have the plug them back in at some point) , but he also said it wasn't working properly.
I fixed my 98 with a simple simple fix (simple design), but i learned from billydpowe that the design changed in 98 to a more complicated design , and this explains why some 98's, all 99's & 00's are more complex to repair.
ewoodru
09-06-17 11:42 AM
