Off Road Build Advice
Hey LS400 Forum,
I hope you and your LSs are all doing well and I have decided to take a somewhat radical approach to my LS400 build.
I know many will hate me for it but I've decided to turn my 1992 LS400 into an off road rig of sorts.
I have gone through most of the mechanical items now and I would like to start on the fun stuff now- a lift with off road tires (29/30in goal).
There are a few (I've only seen 4 different ones online with no build specs) lifted LSs out there but there is not a lot of info on rim size, lift specs such as did they use a coil spring spacer or longer length coil springs.
Do any of you know of coil springs that would be a direct fit for a 92 LS?
My goal is a 3 maybe 4 inch lift to fit 29/30 inch ties.
I would be open to the idea of going for a slightly smaller tire size (maybe high 20s) but I would like to have some decently chunky off road tires on there.
Without having to cut the fenders, is there a suggested tire size if I do a 3 or 4 inch lift (and can you suggest coils)
Thank you all and take care,
David
David
spuds (04-01-18)
spuds (04-01-18)
Hope you make it happen,would really like to see this build.Some beefy BFG all terrains,pick your camo paint...major cool! Reminds me of Red Foreman..."This is a Vista Cruiser,you could literally CRUISE THE VISTA in this car"
I have occasionally seen an off road oriented 89-94 on instagram, I don't recall the owner's handle off the top of my head, but I'll see if I can find it. It seems possible they might be willing to give some basic information.
edit: the instagram user's handle is @kmarowitz. He's posted pictures with other similarly lifted LS400s in the past.
there was a member here that did this to his LS awhile back, i cannot seem to find the thread. pretty radical LS!
as for the actual lift, you will definitely need to alter the body to get wide tires to fit. lifting a vehicle is much harder than just elongating the struts. you will run into positive camber issues!
