Need advice ('93 LS400) - Pressure buildup even after fuel cap gasket replacement
Old 04-01-18, 05:37 PM
dataDave
dataDave's Avatar
Default Need advice ('93 LS400) - Pressure buildup even after fuel cap gasket replacement
I recently replaced the old fuel cap gasket with a new one because I noticed pressure build-up in the fuel tank. However, even after installing the new gasket the fuel tank seems to build up pressure which is released when I start to unscrew the fuel tank cap.
Would anybody know why this could still be happening? I thought it may be due to tightening the cap too tight, but I tighten it until it clicks as you are supposed to..
I have it tight but not till the clicks right now, and will find out if that may be a cause of the problem.
Old 04-01-18, 06:41 PM
Yamae
Yamae's Avatar
I worry that the vapour system is not in a good condition. Have you checked the canister and other components/lines related to the vapour?
Old 04-02-18, 08:54 AM
dataDave
dataDave's Avatar
Yamae, No I have not. I actually do not know the components you are talking about. Could you point me in the right direction? Thanks.
khalid80
10-19-18 11:27 PM
dataDave
03-31-18 12:30 PM
pacerdonfl
02-27-16 01:31 PM
fastegg
07-27-15 05:17 AM
matchesLS
12
09-25-12 04:31 AM
Quick Reply: Need advice ('93 LS400) - Pressure buildup even after fuel cap gasket replacement
