Leaking???? Water???
Old 04-05-18, 10:40 PM
kambam3627
kambam3627's Avatar
Default Leaking???? Water???
Noticed everywhere I go I leave more than oil stains..... but now puddles of water??? Yes puddles. Nothing to splash in but noticeable from a far. On the passenger side of the car about a foot or 2 behind the wheel, almost directly under the passenger seat, what could this be??? AC hose leak???
Old 04-05-18, 11:54 PM
RA40
Super Moderator
RA40's Avatar
Are you using the air conditioning? Usually they drain in pairs on the left and right side. Ours drains more condensation on the right/passenger side.
Old 04-06-18, 12:01 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
It's not leaking, you're running the AC and the evaporator water is vented to the ground. Like literally every other car made.
Drive around without the AC on and you won't see it.
If it was coolant you'd smell/taste/see the difference and it generally isn't hat far back. Where you are is literally where the vents are.
Old 04-06-18, 11:20 AM
timmy0tool
timmy0tool's Avatar
yes, this is the AC condensation, just like a cup of cold water condensates or "sweats".
it is drained to the ground as designed!
turn off the ac and it will go away!
any AC system, even beyond a car (i.e home AC) needs to drain the condensated water build up.
Old 04-07-18, 08:07 AM
Leeroy
Leeroy's Avatar
I'd like to throw in there, if the fluid is clear, but somewhat oily, check to make sure that your heater control valve is not cracked and leaking.
blkvader
09-13-21 08:05 AM
leftyguns
GX - 2nd Gen (2010-2023)
07-26-18 07:11 PM
Tantrix
08-10-16 04:47 PM
mydawgz
08-03-10 07:11 AM
shine
Maintenance
07-17-07 10:52 PM
Quick Reply: Leaking???? Water???
