First oil change and filter (FOR ME)
When replacing the filter do I need to fill it up? I know you lube it but do I fill it up or install without any in it? And do I do this before or after I change and put the new oil in, thanks.
I prefill mine half way as it aids in getting the pressure up faster upon initial startup. doesn't hurt!
I do my filter first, remove old and put new.
then I drain the oil and fill that afterwards.
if I reversed that order I would be contending with a full pan of oil as I tried to remove the filter...messy!
i used to just put some around the seal, never filled the filter... i never understood if that's a requirement... but i guess it's same as when you change the oil, start car for a min to build pressure then check levels again since you know the filter will have taken up the space and you will need to top top off a lil.
It certainly cannot hurt, but not needed IMHO. I did this (pre-fill cartridge housing) on my Porsche, but my Lexus V8 will not be run nearly as hard my flat 6 was and those few seconds needed to build pressure due to an empty filter is inconsequential.
Also, I have always seen two fill amounts for an oil change. I think mine is 5.6 qts. w/o a filter change and 5.9 with, which leads me to believe a filter will hold about 11 oz.
Eddie
Eddie
azncapcom
06-15-20 06:51 AM
alpinefun
ES - 6th Gen (2013-2018)
10-09-19 10:58 PM
lilbluu
06-01-10 03:44 AM
