Improving oem.rear lateral.arm.
Old 04-23-18, 08:23 PM
YODAONE
YODAONE's Avatar
Default Improving oem.rear lateral.arm.
LS400 Rear Lateral Arms employ a welded bracket to connect to the rear stabilizer bar via linkage...
I can move the bracket slightly side-to-side in line with bar lemgth with my bare hands..
If I can do so, then plausibly the stabilizer bar can impart more flex on this bracket.
So am proposing to fortify said bracket to increase rigidity and reduce unwanted flexation to stabilize rear stabilizer bar performance...inexpensive to do.
The offending bracket is atop rear Lateral Arm and connectd to rear stabilizer bar via stabilizer bar.link (viewed just below bend of brake line hose)
Old 04-24-18, 10:17 AM
timmy0tool
timmy0tool's Avatar
you sure you are moving the bracket and not the bushing it's mounted on?
the bushing is soft just like all the bushings on the suspension to give that lexus plush ride quality.
Old 04-24-18, 11:26 AM
YODAONE
YODAONE's Avatar
So the image provides location of rear lateral arm.
Not holding the bushing but onto mounting bracket located on lateral arm....
AlaskanLS
03-02-19 09:17 PM
JAB
RX - 1st Gen (1999-2003)
10-14-13 02:39 PM
FIGS
Suspension and Brakes
61
03-30-12 09:36 PM
micronesia
09-24-10 09:22 PM
2jzsc3
12
04-05-05 07:09 PM
Quick Reply: Improving oem.rear lateral.arm.
